1985 honda atc 70 with problems
nevermind I guess you went to bed....[img]i/expressions/face-icon-small-happy.gif[/img]
1) check to see if you are getting gas to the carb(remove the fuel line from the tank to the carb)
2) see if you have spark(remove spark plug, set the plug so it will ground out, and pull start it, look for spark)
3) do a compression check(install a compression tester in the plug hole and pull start it)
Then tell us what you come up with
I do not know the shift pattern on a 70 but someone on here will help you with that
you should of mentioned that first...[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img] did it run real good after you pop started it?
