'85 250sx problem with kickstart staying up
I took the kickstart arm off of the trike and then removed the right engine cover to fix a gear in there. The inside shaft for the kickstart came out while I was working on it, it had a coili spring around the end of it. When I put it all back together and started it, the kick starter would not stay up. It stays up fine, until the motor starts then it falls all the way down and makes a terrible clattering sound. I was just curious if I put that spring in backwards or something and what is the correct way to reinstall it.
Thanks
Thanks
Mojave250A
07-11-2015 10:38 AM
