Tri Z problem ?
Old 11-27-2006, 01:14 AM
OzzyZrider's Avatar
Default Tri Z problem ?
G'day all. First time in the forum, its great to read all of the threads, and if you haven't guessed I own a Tri Z 250 (1985) down under in Australia. Just wanted some feedback on the following. I was riding on the weekend on the beach, temp was 35 C - which is about 95 F - and after about an hour started to get a surging problem while in top gear going at a decent pace. I had to end up stopping for about 20 minutes and after that resumed and all was ok. Has anyone had this happen to them ? Would it be that the bike was too hot ? Although the temp light (which works) didn't come on. Thanks.
Old 12-26-2006, 07:39 PM
trizinNY's Avatar
sometimes the fuel pump cant keep up at a fast pace they were noted for this..any problems since? could possibly need to clean the carb and jets.you can also check for a air intake leak by starting it letting it idel and spray some carb cleaner around the intake boot for a cracked boot.
Old 01-07-2007, 07:47 PM
OzzyZrider's Avatar
Thanks. No, no more problems to date but I will clean the carby and jets and see how I go.
Old 01-11-2007, 09:10 AM
carlw's Avatar
go run it wide open doun the beach and pull the plug see what it looks like.
Old 01-13-2007, 08:09 PM
Billy08's Avatar
Im not sure if u were going through any water, but i notice with my atc, when i gp through water and the engine gets wet, it seems to cut out on me, and i have to shut it off to let it dry a bit, then it works best kind.
greg74
09-10-2019 03:03 PM
ogio117
Polaris Side by Sides
04-29-2019 03:14 PM
ScopeZ_
07-28-2015 01:44 AM
Ty64
Technical and How-To Articles
07-25-2015 02:02 PM
hondarider1234
07-21-2015 11:53 PM
Quick Reply: Tri Z problem ?
