185s carb/throttle
Old 01-18-2007, 10:47 PM
Tobalias's Avatar
Default 185s carb/throttle
I hope you guys can help. 1st thing i bought a 185s for 100bucks and it looks brand new the only thing is i can get it to run pefect. At idle it misses just a real tiny bit and When i let it idle then give it WOT it bogs out . I don't know alot about carbs this is really my first 1 I never worked on them . But i took the carb apart & cleaned it real good & put a carb kit on except the 1 screw that is set but the factory . Could the miss be a bad exhaust valve or is runin to rich i cant figure it out. I looked at almost every thread thats how i got to understand a little bit . I just cant get it tuned in ? Thanx in advanced
Also the plug gets black so that means ..... Too rich?
Old 01-19-2007, 05:46 PM
wrestleu's Avatar
Sounds like you need to adjust your air mixture screw. Turn it in all the way tight, then back it out 2 turns, and adjust as needed. Also, first check your air filter. That won't have a huge impact on your running rich, but it may have something to do with it bogging down when goosing it. I'm no carb expert, but I had a very similar problem with mine a while back.
Does it smoke at all?
Old 01-19-2007, 06:16 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
i would take the carb apart and clean the needle jet, pilot jet and main jet
Old 01-19-2007, 06:57 PM
wrestleu's Avatar
I thought he said he just put a rebuild kit in it??? I guess that could be the culprit, but unlikely if you put a carb rebuild kit in, and your petcock/filter is working properly.
Old 01-19-2007, 07:01 PM
Tobalias's Avatar
It smokes a little only when u give it throttle . Today I got a new carb for a 185 I put it on & still the same result. I just cant figure it out. The fuel/air ratio screw is preset from factory.
Old 01-19-2007, 07:04 PM
Tobalias's Avatar
Do u think it could be the petcock ? IT has no filter . could the petcock be given 2 much fuel ?
Old 01-23-2007, 06:22 AM
Bing's Avatar
Super Quad Patrol
sorry about my last post
i didnt read your whole post
as far as the preset from the factory mixture screw
if you remove the bowl,,,,the screw will turn full circle,,,right? is it set to 2 turns,,,,from when you put the rebuild kit on?
does the engine have good compression?
where did you find a rebuild kit? I was unsuccessful when i was looking for a rebuild kit for my friends 185 (3 years ago)
Old 01-23-2007, 09:03 PM
Tobalias's Avatar
The engine has good compression. It runs good i just don't like that its not tuned proper. I got the rebuild kit off ebay. The carb I got there too for $50 brand new . The fuel/air screw has black mark on it 2 line it back up if u turn it 's just been cold lately so i haven't touched it . thanks alot for the help
superdizzyboi
ATC 3-Wheelers
08-30-2015 07:22 PM
fourtraxmike
04-28-2005 01:53 PM
robg
03-21-2001 09:05 PM
63tbirdrick
ATC 3-Wheelers
01-22-2001 07:50 PM
garyc660R
10-25-2000 10:59 PM
Quick Reply: 185s carb/throttle
