81 Honda 200 wont fire !
Old 05-05-2010, 09:20 PM
bobmilla69's Avatar
Default 81 Honda 200 wont fire !
The 1st time i got this Atc all i had to do was clean out the carb, and it fired right up, until on day it just started to stop running, i let it sit in my barn for about 5 years and got interested in getting it running, So i buy a new gas tank , cleaned the carb, changed the plug, pulled the cord to start and got nothing Pulled out the spark plug and pulled again , no pulse or nothing bought a new coil and a new cid box, checked wires for connections still no fire, so im thinking its the stator, but how do you take this thing off ?? i removed the fly wheel and put on a stering wheel puller that would fit for 2 bolts and started to twist the long screw twards the shaft, didnt come loose and now i have another prob the pused the threads back a lil so the nut wont fit on anymore, i can plobaly shaved it down a lil after i get this thing off, if i can only get inside to clean the magnets i might be able to get some fire to that plug, please help me what do i need to pull off the cap to clean these magnets?
Old 05-05-2010, 10:57 PM
bobmilla69's Avatar
what type of puller do i need, and what all should i clean up with sandpaper?
Old 09-09-2011, 11:36 AM
rednix's Avatar
thers a flywheel puller you can buy i picked one up for 20 dollars at the honda store not sure what kind of sandpaper to use my trike is having the same problem though
Old 09-12-2011, 09:49 PM
crispy1960's Avatar
If you put the puller on and snug it up, you should be able to break it free with a sharp tap from a hammer on the end of the puller shaft, then either file the mushroomed end or preferably get the proper die nut to clean up the threads.
08-05-2015 02:10 AM
cornermike
07-30-2015 06:37 AM
toonces
07-24-2015 09:03 AM
07-22-2015 05:00 AM
CRamshaw777
07-18-2015 05:46 PM
Quick Reply: 81 Honda 200 wont fire !
