Bike Project Problems
Old 11-07-2010, 10:46 PM
DirtMX57's Avatar
Default Bike Project Problems
I'm having problems with my gear shifter. I bought a bike months ago from this guy on craigslist. it had a honda ATC engine ( i beleive it's a 81) and a Yamaha quad body on it, it ran fine, until i tried changing the oil.....well i couldn't get the drain bolt to crack so i pumped the oil out then added new oil. okay then.... it wouldn't change gears! my gearshift wont hardly move! like i have to push HARD and i even bent it in the process. so then i found a screw just above the hi/low gearbox and it looked like i could add gear oil in it..ok i put gear oil in and fire it up...still wont go! so then one day i played around with the screw above the gearbox and found out it had a springand the thing that switches it from hi to low well the spring fell down inside the dang gearbox!!! i'm at a dead end here guys!!! someone please help!! I want to fix it so badly! I put alot of money into this bike by buying parts for the recoil starter,buying a hose for carb and spray painting it. so i really want to fix it. I cant mess with it til 2011 because i'm having a knee re-alignment coming up soon. but if you would, please study it for me? i'm a do it myself girl and i've learned alot of stuff on my own just by messing with bikes but i'm stumped here.
Thanks,
Jessie
Old 11-09-2010, 03:05 PM
justme23005's Avatar
where are you located?
jrooker6
Ask the Editor
11
04-21-2016 07:35 PM
NDoud44
06-28-2015 10:42 AM
Bassassasian101
06-10-2015 06:23 AM
volsgo30
06-04-2015 06:07 PM
hoopduerr
06-01-2015 08:22 PM
Quick Reply: Bike Project Problems
