Help! Too old to figure it out?
Old 07-28-2011, 09:24 PM
R.T. COBRA's Avatar
Lightbulb Help! Too old to figure it out?
I have an 84 200es which i bought new back then. She got tired, so last winter I had her bored out 50 over; new piston, rings, timing chain, valves, seals, pulser, cdi, coil, carb,.On the bench,she had 150psi. After i put the engine in the frame it had 130psi. Timing and valve clearances are right. At low rpm she has lots of torque, but as the revs. come up she loses power. She wont go up a grade on the road without getting back into low range and 1st. or 2nd. gear. She used to carry me and my lady along easily in 4th and 5th in the high range. I still need the bike to service food plots for deer in my place plus other chores. I really am stumped. The worst is that i build engines for bent toys!!! Thank You .
Old 07-27-2013, 03:33 PM
hermie's Avatar
replace the cdi unit
hondas brain fart of an idea by mounting the coil and cdi overtop of the engine
being cooked by the engine heat
Old 07-28-2013, 06:04 AM
hermie's Avatar
should have read your post more clearly
you bored the cylinder 50 thous over ( way too much over bore )
on air cooled atv engines , you should only bore the cylinder 1 size larger from what the worn out cylinder measured
now you must re-jet your carb to compensate for the now larger combustion chamber
Old 08-15-2013, 11:59 PM
armagh's Avatar
I would have to re check the valve timing. It sounds slow or retarded to me.
wrencher82
09-28-2015 10:02 PM
Barnsnelbon
09-27-2015 03:07 AM
dakotah
09-26-2015 04:25 PM
wrencher82
09-24-2015 03:39 PM
Ricardo Covarrubias
09-17-2015 08:28 AM
Quick Reply: Help! Too old to figure it out?
