My ATC 200x Problems!!
Old 06-07-2012, 02:08 PM
ATC_Dad's Avatar
Thumbs down My ATC 200x Problems!!
I have an '85 200x that dies when it warms up. It will start fine when it is cold WITHOUT the choke. I have rebuilt the carb. new fuel, new filter, factory jets, new air filter, reset timing, and checked cam timing. Any Ideas would really help!!
Second question.
When you install the cam, how do you know if it is 180 out or not? You can set the flywheel at TDC and the cam could go in either lobes up or lobes down. Either way, the valves are closed. Which is correct? Need to know before I put the two cam sprocket screws in..
Old 06-27-2012, 10:02 AM
jagump07's Avatar
mine does the same thing if the choke lever is up 1 position but if flipped down it idles great
Old 06-27-2012, 10:12 AM
ATC_Dad's Avatar
Default Cured.
Finally gave up on the factory carb. Tired of messing with it. Bought an H S Chinese carb from ebay for about $15 and bolted it on. Hit the choke and it started second kick. Warmed up for 2-3 mins and turned off choke. adjusted idle mix..then idle speed..then idle mix again...then idle speed again.
Now runs like a screaming banshee with its @ss on fire and starts second or third kick every time (my 12 yr old starts it just fine), idles great, and runs out great at high end...Good luck. They are great fun when they are working right.
1978 ATC 90
1985 ATC 200x
2005 Yamaha FZ-1
2 or 3 wheels...makes no difference to me.
Old 06-30-2012, 12:43 AM
sinsayers's Avatar
watch those ebay carbs, they tend to need rejetting but if yours works then good deal. I have heard many guys complain about the jets in those.
Old 08-24-2012, 10:12 AM
beecj0's Avatar
Default new carb
What size carb did you go with?
greg74
09-10-2019 03:03 PM
ogio117
Polaris Side by Sides
04-29-2019 03:14 PM
ScopeZ_
07-28-2015 01:44 AM
Ty64
Technical and How-To Articles
07-25-2015 02:02 PM
hondarider1234
07-21-2015 11:53 PM
Quick Reply: My ATC 200x Problems!!
