1984 200s atc project, need some help
Old 06-11-2012, 05:42 PM
BatonVeck's Avatar
Unhappy 1984 200s atc project, need some help
so i got the three wheeler, cleaned magneto contacts, thouroly cleaned carb....3 times. and she ran well for around 5 minutes till the rear tires went flat, then she bogged down and died. tried to re start, and after 5 mins of pullen on the pull start she fired up with the throttle hammerd down. ran putter in for about thirty seconds and died. tried again and then again fiddlen with the carb screws and still nothin. good spark and spark plug and gettin fuel so what am i missing? help is greatly apreaciated
Old 06-30-2012, 01:05 AM
sinsayers's Avatar
Check the main jet again, sounds like it could be plugged also check your pulse generator and make sure it is ok. Whoever had my 200X apart before didnt put the washer on the 6mm bolt that holds the rotor on and it would run for a while but quit eventually because the rotor would pop off. Its a shot in the dark but hope it helps
Old 07-03-2012, 04:43 PM
BatonVeck's Avatar
Default got it!
so when i put the carb back together i didnt tighten the main jet screw all the way, and when i fired it up the first time it must have rattled loose. i got feed up with pullen and pullen that i checked and traced all the wires, checked all the breether tubes, and finnally tore the carb off, i heard some rattlin and bam, the stupid screw came out. so put it back in. bought a new sparkplug and now i am annoying the nighbors cause i am flyin up and down the roads! and takin corners at around 35
Old 07-03-2012, 10:39 PM
sinsayers's Avatar
great news man, these things are a blast.
Specta
Family ATVing Photos
12-07-2018 08:22 PM
dannytas
09-26-2017 06:31 PM
mywifesquad
8
09-21-2015 08:20 AM
bmark0610
ATC 3-Wheelers
09-07-2015 07:57 PM
bmark0610
ATC 3-Wheelers
09-07-2015 07:48 PM
Quick Reply: 1984 200s atc project, need some help
