85 tri Moto 225dr engine swap
Old 08-25-2013, 02:11 PM
Tbroady2002's Avatar
Default 85 tri Moto 225dr engine swap
So I got this bike in a basket and after I got it back together I got something wrong and it doesn't shift properly. Had a shop look at it and they screwed me over and didn't fix anything. It's a 85 Yamaha tri-Moto 225DR a buddy of mine has a tri Moto 185 motor. My question is....is the bottom end and transmission the same on the 185cc an the 225cc. Thanks for your help.
Old 08-25-2013, 11:14 PM
Not sure if this is a really stupid question or maybe nobody knows because the smart thing would have been to get a 200x but its my curse to think out side of the box and go against what everybody else has. But at this point I've got too much $ into it to try and sell. Plus it's a really clean bike. So if anyone knows where I can find this info it would be apreciated.
Old 08-26-2013, 06:13 PM
newfiebullet's Avatar
didnt know yamaha made a 185? i wouldn't downgrade, look for a 250 timberwolf or bear tracker....takes a little bit of work to get the carb to fit right but worth it. i put a 2002 beartracker motor in mine. you will need the whole harness for the BT motor..the 200e/er 225 dr/x and timberwolf/beartracker all have the same base and bolt right in. only diff is the carbs and bigger heads...the TW and Bt have longer universals that have to be swapped.
bzdok1234
30
02-23-2016 01:55 PM
toonces
07-28-2015 01:58 PM
TheHood
07-26-2015 09:51 AM
tweeder
07-05-2015 01:57 PM
bzdok1234
Utility ATVs
07-03-2015 05:32 PM
Quick Reply: 85 tri Moto 225dr engine swap
