ATC 110 carb problem
hello, I have an 1985 i think ATC 110. I had take apart entire lower end to fix the transmission but when i got it all back together and got it to run, whenever I would give it gas, it seemed to bog down or not get gas, I cleaned out the carb, adjusted the throttle and choke but after everything it still isn't getting gas when I give it to it. and I noticed at one point that there was gas coming out of the tube towards the base of the carb I'm not sure if that has anything to do with it but I thought it might be important. I would appreciate help fixing this instead of buying a new one since I'm low on money. thanks!
