Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
Weight
Old 07-29-2015, 03:19 AM
Ashley S's Avatar
Default Weight
I weigh around 17 stone = 238 pounds.
Would a 250cc - 350cc or even a 450cc hold my weight?
Yamaha quads.
Old 07-29-2015, 07:15 AM
Scooter86's Avatar
Knows Old ATV Questions!
Yes, but you will be most comfortable on the 450 or 700 models. Height is a big factor as well, the 250 is for smaller riders. I am 5'9" and the 250 raptor an blaster models are ok, for about 30 minutes. Then I crave something larger. The utility and 4x4 models tend to run a bit bigger. Try before you buy.
Old 07-29-2015, 01:27 PM
greg74's Avatar
Probably a Raptor 660 or 700 would be better. The yfz 450 is great for racing but they require a lot more maintence and need to be revved high to get the power out of them. The bigger engine in the Raptor makes a lot of power but it can just as easily putt around at slower speeds as well.
Old 07-30-2015, 08:38 AM
TLC's Avatar
TLC
TLC is offline
Weigh is not the problem its room. ATVs come in 3 chassis sized small, mid and full.
Example in Honda utility.
Small chassis =250 Recon
Mid chassis= 350/420 Rancher
Full chassis= 500 Foreman/Rubicon
Weight wise even a 250 Recon is rated for much more weight then 250lbs. but do you want your knees up beside your head all day?
shimanok2
01-29-2016 07:37 PM
Robinhood
12-26-2015 10:28 AM
Steeldon
09-09-2015 09:38 AM
Steeldon
Utility ATVs
09-05-2015 09:38 PM
Quick Reply: Weight
