Ok to use Rotella T6 5W-40 in my Grizz 700?
I'm wanting to run Shell Rotella T6 synthetic in the 700 Griz but I can only find it in either 0W-40 or 5W-40 weights, and the manual says it's ok to use everything BUT those weights...5W-30, 10W-30, 10W-40, 15W-40, 20W-40 and 20W-50.
Would it be ok to use the Rotella 5W-40 or do I need to stick to what's specified in the manual?
I've used it in an old Honda Nighthawk,my son used in both his SV650 and SV1000 Suzukis and no problems whatsoever. Just google this oil and all the people that have used it in cycles and atvs or look on other forums.Yamaha Grizzly 550 and 700 owners | Power Sports | Bob Is The Oil Guy Plus doesn't have the friction modifiers that can cause slippage on manual transmissions also. A good all around oil that's cheaper than a lot of other full synthetics.
Not sure how a low 0w-40 can hurt. The 0w just means it's a thinner oil only on cold starts which is a good thing , once up to temp it's a 40 weigh like any other. Here's a good link about how multi grades work.
Oil Specifications Explained - What does 10w40 mean?
I only use Amsoil 0w-40 in my 350 Yamaha and it been fine. it just has a wider temp range.
