Utility/Sport
The Scrambler 850/1000 at least has a rear rack. The Renegade has one you can add as an accessory. The Scrambler rack doesn't have nearly the capacity of the Sportsman or any utility quads racks though. Its basically just for hauling a cooler or small toolbox. So as long as you don't want to haul anything too heavy, it would be fine.
#15
#16
Grizzly 700 is a good work quad and pretty fun too. Single cylinders tend to have more low end grunt than twin cylinders. Not that the Sportsman or other twin cylinder machines are shabby. They'll pull more than the makers suggest. Biggest problem with heavy trailers is coming to a stop. I've pulled an industrial sized wood chipper up a wet grassy hill that trucks couldn't get a good enough grip to move with a 500 single cylinder. I wouldn't do it all the time, but the power is there if you need it.
#17
#18
The Scrambler, Renegade are the same ATV as the
Sportsman and outlander but with sporty plastics and no Racks. There is no true sport 4x4 ATV.
check this specs link 2016 Polaris ScramblerŽ XP 1000 Titanium Matte Lime ATVs Same same machine.
Having no racks will not make the Scrambler go up a dune any better than a Sportsman.
#19
They used to with the Wolverine 450 4x4. They built it from 2006-2010. I had one myself a few years ago. I liked everything about the machine except it needed more power. If Yamaha had simply put the Grizzly 700 engine in it, problem solved. I think it didn't sell very well because the Renegade and Scrambler were more powerful and most people bought those. Or they just bought a Grizzly 660 or 700. The Wolverine was a lot smaller(and lighter) than the Renegade and Scrambler though. Torquey engine that lacked top end power. I think they were geared a bit lower than the Kodiak 450 that shared the same engine because of lack of a low range(which also saved weight). If you can find a Wolverine 450 4x4 used, they're actually not too expensive. A great trail quad but get out in the open or try to climb some dunes with them and you discover the limitations in power.
#20
