Just DS650 facts, nothing else
Type 4 stroke, 1 cylinder double overhead camshaft
Displacement 653 cc
Cooling Liquid cooled
Radiator Front mounted
Coolant Glycol/water 60/40
Max RPM 7700 RPM
Starter Electric start; start in any gear
Lubrification Dry sump
Decompressor Automatic
Carburator Mikuni BSR42 Manual choke
ACG 290 W range - DENSO
Clutch 1 multi-disc
Transmission 5 speed
Chain 530 Type
Front type Independent
suspension–double A-arm
Front travel 12,0 in. (305 mm) travel
Rear type Rigid swing-arm
Rear travel 11,5 in. (292 mm) travel
Pilot lamps Neutral indicator
Oil pressure/coolant temperature
Dry weight 460 lb (est.) (209 kg.)
Max. length 77 in. (1956 mm)
Max. height Overall
46,5 in. (1181 mm)
Max. width 50 in. (1270 mm)
Wheel base 52 in. (1321 mm)
Wheel track-Fr. 41 in. (1048 mm)
Wheel track-B. 39 in. (990 mm)
Turning radius 8 ft. (2.4m)
Fuel tank cap. 12.2L (3.5 US gal.)
Tires front 21 X 7 X 10 in.
Tires rear 20 X 11 X 9 in.
Rims front 10 in. diam. X 6 in. Wide
Rims rear 9 in. diam. X 9 in. Wide
GROUND CLEARANCE
Front & under engine 11 in. (279 mm)
Rear axle 4.75 in. (121mm)
Battery 12 V, 13 A dry type battery
Headlight 60/55 W.
Taillight & Brakelight 8/27 W
Front Nissin hydraulic, 2 discs (stainless)
Rear Nissin hydraulic, 1 disc (stainless)
Parking R.H. brake lever includes a lock on front wheels
©1999 Bombardier Inc. All rights reserved. *, TM : Trademarks and ® : Registered Trademarks of Bombardier Inc. and/or affiliates in the United States of America. In U.S.A
Displacement 653 cc
Max RPM 7700 RPM
Clutch 1 multi-disc
Chain 530 Type
Max. height Overall
46,5 in. (1181 mm)
GROUND CLEARANCE
Headlight 60/55 W.
I seen that it had 54 hp but i also seen 48> the time i seen 54 it was at higher rpms though
99 500 scrambler with hotseat pipe and clutch dg bumper soon to have pistons and air box mod 93 yamaha t-wolve with a broken taillight soon to be fixed tailight is now fixed now need to fix headlight
Customer Service #1
05-15-2020 08:46 AM
