Outlander 800/R VS. Kawasaki Brute Force 750i
#21
<div class="FTQUOTE"><begin quote>Originally posted by: raptoredd
I need to correct this, the wheel slipped then locked in the other one, but isnt that what a ls does.</end quote></div>
Limited slip gives the slipping tire traction, thus stopping the tire that is getting the traction. The Visco system is just the opposite, it gives even more traction to the tire that already has traction at the same time as stopping the other from spinning.
#22
<div class="FTQUOTE"><begin quote>Originally posted by: SilverBomb
Limited slip gives the slipping tire traction, thus stopping the tire that is getting the traction. The Visco system is just the opposite, it gives even more traction to the tire that already has traction at the same time as stopping the other from spinning.</end quote></div>
Actualy No a LSD needs to have partial traction on both wheels thus allowing for more engine torque to be tranfered to the wheel with the most traction, Simaler design to Viso lock but not the same as Visco lock useses the Spinning wheel to build Hydolic pressure locking the front axles together thus getting traction till the spinning wheel regains traction. Most amature racers and pickups use LSD systems in there race cars and trucks and it works better in those circumstances.
http://www.eaton.com/EatonCom/...ials/PosiLSD/index.htm
#23
#25
<div class="FTQUOTE"><begin quote>Originally posted by: Cardiac
Don't the high dollar racers use a Visco lok system in their all wheel drive super cars?</end quote></div>
No a Spool (Pernament Lock). Not good on the streets! [img]i/expressions/face-icon-small-wink.gif[/img]
#27
Your not you are locking the axles together so that there is no spin getting the power to the axle that has traction therfore moving you forward. There are just diff ways of accomplishing this but they all end up doing the same thing it just depends on which works better for you application.
#28
Limited slip differential (a.k.a. positraction) send the torque to the NON-SLIPPING wheel. Why would you send more power to a wheel that doesn't have traction to begin with? If you don't believe it, Google is your friend. [img]i/expressions/face-icon-small-wink.gif[/img]
#29
<div class="FTQUOTE"><begin quote>Originally posted by: 4strokemurder
its pretty much personal preferance. i for one cant stand visco lok.
ill say go with Kawi. it isnt as powerful but you'll thank yourself when your still riding it 5 years later. lol</end quote></div>
hmmm..... i have had my ol650 for almost 3 years now, with 4000 miles and put it in most every kind of terrain you can think of and only had rear u joints go bad.....i would like to know where your basing your information from!!!!
#30
<div class="FTQUOTE"><begin quote>Originally posted by: BBR650
hmmm..... i have had my ol650 for almost 3 years now, with 4000 miles and put it in most every kind of terrain you can think of and only had rear u joints go bad.....i would like to know where your basing your information from!!!!</end quote></div>
He pretty much has no clue. [img]i/expressions/face-icon-small-happy.gif[/img]
