02 ds650 timing chain and tensioner
hey guys im new here but i have been around powersports all my life. my family used to own a brp,suzuki, ktm dealer so thats where i would get all my parts. but now i dont know where to get parts cheap lol
so far i need a timing chain, a timing chain tenioner and a complete gasket where is the best place to get that stuff?
Some of the better places that most of us have found over the years are Parker Yamaha, Parket AZ, Proshop Motorsprts and Marine in Henderson NV, BikeBandit has been good for some.
Best thing to do is Google the DS OEM fiche and compare the prices of those that come up. Temecula Motorsports is another that comes to mind.
Doesn't hurt to tell them that so and so has it for this price, can you meet or beat it if I get the rest of the parts from you. Most will work with you if they feel they are going to get your business, especially with the market like it is now.
If you fine any cheaper than those listed please post them so that we can all give them our business.
ok so it sounds like a dealer or bike bandit then lol
what is the tensioner supposed to be like on these things? i cant figure out how mine would be able to tension anything since there is no spring behind it or amy way put pressure on it unless its a a 2 peice thats seized up. its been to long since i have messed with one so im kinda relearning these rotax motors
Press in on the ball bearing down in the center of the housing with a small tool while squeezing on the assembly & see what happens - it may be seized if it has sat for a while, but this procedure restores 95% of "bad" tensioners.
I do this after each removal & bleed all the oil out of them so they become very easy to compress with just a couple of fingers -- upon reinstallation and oil circulation they will pump back up (very quickly) and maintain proper tension.
Cam Tensioner
I know this is years late but hopefully it will help other people in the future. My issue was I started up my DS the other day and it was making a clank clank type noise, but only at idle. When you would rev it up the sound almost disappeared. Took the valve cover off checked valves everything seemed ok. Changed the oil in it and no metal was found. So I tried pulling the chain tensioner and mine was completley compressed. I ended up ordering a new one "and there is a part change with a redesign for it" and after the 1min. swap it started knocking again for a good 3 seconds and then like magic she was quiet! Hope this helps before any of you start overhauling that rotax motor
