special tools for maintenance on the DS650
Old 08-16-2009, 01:26 AM
SilverBomb's Avatar
SilverBomb has got an Addiction!
Originally Posted by talonxracer
I discovered that the internals of my stock muffler had been already modified, there is only the two outlet stubs left on the inside of the end cap.
I had heard that this is almost as good as most slip-on type mufflers, is that true?
An open end cap on a stock exhaust is as good as most slip on pipes.
Old 01-15-2017, 02:05 PM
Joe with a problem's Avatar
Default Ds650 will not start
i have a 2001 ds650, one year ago I could not start it so I hope someone can give me some ideas to help get it started. It is factory except for the dynamic ignition box which was put on one year ago. I check via the spark plug and I do have spark. I check the timing and it is on the money. When I turn it over using starting fluid it pops through the carb. Also the carb was new two years ago. It does not fire only a pops. If someone could help I would appreciate it. Thanks
Old 01-17-2017, 03:01 AM
MRDS650's Avatar
Canadian and Proud of it !!!
I would first swap out that ignition box and try, they do have a chance of going bad
Old 01-17-2017, 05:18 AM
Default Thank you
I will try to look for a cdi box.
dannytas
09-26-2017 06:31 PM
Alex G.
09-11-2017 11:38 PM
cboler9
09-24-2015 08:35 PM
MikeyBoyesq
09-22-2015 10:02 AM
caveeagle
09-19-2015 01:20 PM
Quick Reply: special tools for maintenance on the DS650
