Coil Spring Spacer idea.
Saw this on the Can Am forum, instead of using PCV, why not aluminum Cam lock adapters? Stronger, and safer.
2" RDC spring spacer lift - Can-Am ATV Forum
2" Cam Lock female adapter.
2 in. Cam-Lock Female Adapter | Princess Auto
And the link to bigger in case our struts are larger than 2".
Powerfist | Princess Auto
Rubberdown Customs also makes aluminum ones.
Also, Lift kits sold by Highlifter and RDC use the spacer at the bottom of the coil, yes it is safe.
