Bombardier Quest Solenoid Replacement/Shop Manual
My Quest 650 won't start. The starter tests good but the separate solenoid won't pass 12V so it is bad. It clicks when I press the starter but no juice to the starter. The solenoid is a press fit and I can't pry it apart to fix it. The shop wants $120 for a new solenoid but I figure any old solenoid should work.
There are four posts on and two wires into the solenoid whereas most solenoids only have 4 posts.
Does anyone have a shop manual or a link to a shop manual for the Quest?
Or does anyone know what the four posts and two wires are? 12V in and out are obvious as well as ground but I need to figure out the 4th post and the two wires.
Many thanks
Dwight in the Cold North!
Many thanks
Bombadier 650 starter relay solenoid whatever
[QUOTE=Mountainwaves;3278671]My Quest 650 won't start. The starter tests good but the separate solenoid won't pass 12V so it is bad. It clicks when I press the starter but no juice to the starter. The solenoid is a press fit and I can't pry it apart to fix it. The shop wants $120 for a new solenoid but I figure any old solenoid should work.
1 has a nut on mine I have no clue did u get any help God I hope so I'm over my stupid mistake I know better 4 the next 1 pic b4 removing
much tkx
Jocelyn FuckMeMT77
Many thanks
Dwight in the Cold North![/QU
much tkx
Jocelyn FuckMeMT77
Many thanks
john luttrell
8
05-26-2011 08:05 PM
jrAustin
1) Engine problems..
06-02-2010 11:43 AM
