Suspension Upgrade
Old 04-02-2015, 08:56 AM
Chevy3131's Avatar
Default Suspension Upgrade
I have a 2014 Outlander 500 and the factory suspension is way to soft. Wondering if anyone has upgraded their shocks due to this issue and if so can you please point me in the right direction to for a little stiffer suspension
Old 04-02-2015, 09:21 AM
TLC's Avatar
TLC
TLC is offline
Since the Renegade X is essentially the exact same machine as the outlander http://www.atvreviewnetwork.com/enth...2=309729&go=Go with the same SST G2 frame but with upgraded FOX PODIUM Performance RC2 HPG piggyback shocks they should just bolt on.
Or you can add springs spacers to stiffen it up. Do you have them clicked to the stiffest setting?
Old 04-02-2015, 09:42 AM
Chevy3131's Avatar
Thanks and yes it is on the stiffest setting. I will look into those Fox Springs
Old 04-02-2015, 09:55 AM
TLC's Avatar
TLC
TLC is offline
You could try a spring spacer they come in rubber or metal and go on top of your existing spring to stiffen them up.
I bought HD (Heavy Duty) springs for my Polaris when I first bought it maybe Can-Am offers the same thing instead of a entire Fox $hock.
Here's how the spacers work. I,d buy the metal ones not rubber if you go that rout.
Their are hundreds out there. https://www.google.ca/search?q=shock...2F%3B800%3B800
Old 04-02-2015, 06:10 PM
brain21's Avatar
it's very good
Robinhood
12-26-2015 10:28 AM
jankerstien
09-21-2015 03:09 AM
bigred20653
09-19-2015 02:11 PM
Bonzhonda300ex
09-17-2015 10:44 AM
Brandon400
09-05-2015 08:44 PM
Quick Reply: Suspension Upgrade
