DS650 Clicking - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 11-15-2016, 06:48 AM
Default DS650 Clicking
I recently picked up a extremely clean 2000 ds650 on a trade for some items. It was not running when I got it. When I brought it home I noticed it had a cracked starter so I replaced it along with the one way sprag. Bought a new battery and hooked it up and just clicks by the solenoid. Thinking that was the problem I got a new one and put it with same result. I tightened all the grounds/wires and noticed it was a cluster so I ripped all the wiring out and bought an untouched harness and installed. With new harness in it does the exact same thing. Just clicking. I bought a new starter solenoid and same thing. Even tried a known battery from my 700. I also notice with the clutch pulled it only clicks one time. When i release the clutch it does multiple smaller clicks but no change. Could the cdi be shot or is there any way to check. Thanks
Old 11-18-2016, 07:10 AM
Canadian and Proud of it !!!
I am thinking your issue is the couple of spacers on the little gears that connect the starter to the spraug clutch. I have made this mistake myself. To check it quickly, just loosen the side cover - where the spraug is, loosen all the bolts a turn or two and try to turn it over. if it turns over you know that's the issue. I have attached a pic of where those spacers and washers should go.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
