Kazuma 110 falcon no spark
Old 04-29-2010, 08:37 AM
jamietavis's Avatar
hello i have a 6 pin cdi and have no spark.I need t no what wires go were? thank you
Old 04-29-2010, 10:58 PM
LynnEdwards's Avatar
Electrical Expert
Is this your CDI?
I've never seen a 6 pin CDI on a 110cc machine. Are you sure of the engine size?
Old 05-05-2010, 05:25 PM
towery3's Avatar
my cdiboxesis only a 5 wire
Old 05-05-2010, 10:43 PM
Electrical Expert
Your CDI probably looks like this:
On 5 pin CDI's there is no ambiguity about how they are powered. The power comes from a moderately high voltage AC winding on the stator. On the 6 pin CDI's shown in the earlier post they can be AC powered or DC powered. The CDI's look identical, except that often the DC powered CDI's are a little bigger. Which one you need to use depends on how your quad is wired.
I've taken apart and traced out the internal schematic for a 5 pin CDI, and an AC powered 6 pin CDI. The surprising thing to me is that they were exactly the same inside except for the connectors. Every resistor value, every transistor type, every capacitor value was exactly the same.
I've never taken a DC powered CDI apart.
  #15
Old 05-08-2010, 09:02 PM
towery3's Avatar
had it running but its overloading with gas took carb all the way apart cleaned it good put it back together still over loading with gas could the float be bad
pgamboa
12-24-2023 11:52 AM
fordfaithful21
12-07-2015 05:52 PM
NRA+1
1) Engine problems..
10
09-20-2015 08:47 PM
Cdenton
Technical and How-To Articles
09-09-2015 11:23 AM
jeff mc
Dunes and Dune Machines
09-03-2015 07:47 PM
Quick Reply: Kazuma 110 falcon no spark
