Chinese atv overflow from carb
take it apart again, your needle valve is stuck open in the seat. use a QTip to clean it out and make sure there ain't nothing in it. when you put it back together and before you put the float bowl back on, stroke the float up/down and watch the needle valve go up/down to verify its proper function. if all is good, then install float bowl and go.
before you start your quad, check the crankcase oil for gasoline contamination. i'm presuming your quad is a 4 stroke. we don't need to have a more combustible mixture in your crankcase ready to blow up under your seat due to lots of gasoline in your crankcase. if contaminated, just change oil. if it did get gasoline in there, it was because the float leaked by and into the cylinder and past the piston. no biggie, just get it out of there.
2 things come to mind. On my carb i have a drain and no overflow that has a small screw to stop the bowl from emptying. Have you checked for this? mine is on the bottom of the bowl.. If its constantly dumping fuel your float is set wrong or is not sealing with the bowl of the carb hook it back to the fuel line and check for operation.
https://www.wickedatvs.com/pdf/ATV%2...adjustment.pdf
That link I posted was just for proper adjustment of the float. If float is not adjusted properly the fuel will never stop running and come out your overflow.
My carb has no overflow just a screw to drain the bowl. If you search my posts u will see a pic of my carb. The post was posted this week
