A few questions for you Carb Experts
As some of you may know from my previous post....
This is the Carb setup presently on my son's 2003 Dinli Diamondback 90cc. The quad will start and idle but as soon as you thumb the throttle it stalls out. I don't have much history on the Carb but from what I've read and seen in the Dinli Manuals the Carb is not or nothing close to the look of the factory original nor does it have the wires/wire connector as the factory Carb has on the plunger. It's just a small rectangular Carb.
Since I don't have much history on what it is I'd simply like to purchase an el-cheapo aftermarket Carb online with the plunger and wire connector like this
and install it with hopes that it will solve the stalling issue. Problem is, I have no clue what wires plug into the New Carb's plunger connector.
Hoping someone will chime in giving me some direction because I'm stumped as of now.
Www.buyatvsonline.com try this site for a new carb. Looks like ur carb has an electric choke mechanism. if ur quad isnt made for one u wont b able to use it without some modificafions.
Have you tried cleaning it? Sounds like a plugged jet.
FYI: 1) the stock carb was prolly replaced cuz the electric chokes don't work well. I'd not replace it with another with the electric choke.
2) Dinli's are very fine Tiawanese machines, not china stuff.
If you want Dinli parts go to:: maximumrpm.com. They (justin) was the original importer of Dinli's.
