Buyang 300- Idles fine/Dies with throttle
Old 10-18-2013, 11:06 PM
Txshawn72's Avatar
Default Buyang 300- Idles fine/Dies with throttle
Hello, new to the site!
Buyang 300, long story short, working on it for a friend. Ignition was bad (replaced with new), water in tank (flushed/soaked with Seafoam, dried), water in carb (soaked, cleaned, brass brushed every orifice, jet, etc.) I actually did the carb twice because when I put it back on I had a small leak) New fuel lines, new fuel filter.
Now it fires up real quick, will idle all day long, but if you give it throttle, immediate bog and dies. Thinking choke, (it's electric) but not for sure. Any ideas???
Thanks in advance. Shawn
Old 10-19-2013, 09:21 AM
Zrock's Avatar
Super Quad Patrol
unplug the choke and see what happens.
Old 12-26-2013, 03:59 PM
Jaster94's Avatar
your ratio of air vs fuel is increasing therefore you have a fuel delivery issue. you have more air than fuel when increasing throttle. look over your main jet again, pull and clean. on your choke, if you can cold idle with choke, then that's good. after it gets warm, your choke can kill the quad by overfueling it. not enough air. once warm, then you don't need the choke anymore. so, look over the main jet again. thanks.
Ronk407NY
02-13-2016 11:05 AM
Polarisman1123
09-13-2015 10:06 AM
house1
08-09-2015 10:49 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
07-08-2015 02:16 PM
Robbbb55
07-08-2015 02:11 PM
Quick Reply: Buyang 300- Idles fine/Dies with throttle
