Agravated
Old 04-12-2014, 05:07 PM
carnagejb's Avatar
Default Agravated
I have replaced the stator on my bennche bighorn 700. not getting fire or gas. I cannot figure it out and the dealership doesn't know whats wrong. Please help!!!!
Old 04-13-2014, 08:09 AM
Scooter86's Avatar
Knows Old ATV Questions!
I had never heard of these, so I did a search. Wow, they sure are getting proud of these things! That is a lot of $$ to spend for the dealer not to have a knowledgeable service tech! I would contact Bennche directly at this point, especially if it is still under warranty. Since it is efi and you don't have fuel or spark, it has to be an electrical problem somewhere. Blown fuse? Weak battery? Pinched wire or bad connector? That is where I would be looking.
Old 04-13-2014, 08:39 AM
Zrock's Avatar
Super Quad Patrol
i would grab a test light and start testing from the battery following your power wire up to the switch and beyond. i would say you have a faulty ignition switch, kill switch, or your neutral safety is bad. Is anything else electrical working? not sure if these things have a dash light that let you know if its in neutral?
Old 05-16-2014, 10:43 PM
whygostockcom's Avatar
Banned
ECU or coil. Should be under warranty from Bennche.
martymar
01-11-2007 01:05 PM
paintballbanshee
12-21-2005 02:59 AM
Crayton8700
05-03-2004 06:54 PM
warrior007
12-09-2002 02:26 PM
Quick Reply: Agravated
