Cdi box circuit help needed
on
SPark plug are cheap and easy to change. Ignition coils really cannot be checked completely with ordinary test equipment, so sometimes the only way to know is to put a new one in.
The stator, on the other hand is completely testable on the quad. They're a little more expensive, and harder to change. Thus I would measure the stator AC power output while cranking the engine. Ditto for the CDI trigger signal. Do you have an oscilloscope? Even a meter will work, but be sure to measure the stator outputs with the CDI unplugged. The reason for that is that the stator power winding output is yanked around a lot by the CDI making it very hard to determine if the CDI is bad, or the stator is bad. Note that D2 and D4 in your schematic short the stator output to ground when swinging negative, and D1 / C1 yank down on the stator output when swinging positive - at least until C1 charges up through the ignition coil primary.
If you have an oscilloscope here are some waveforms:
Below is a revised circuit diagram of dt 125 for quadzilla cdi instructions and the other circuit is just a quick setup without pcb if you were to wire it bug style.
http://imageshack.us/f/52/sam4686.jpg/
http://imageshack.us/f/194/yamahadt125part2.png/
