06 jianshe 400 no spark somtimes
Old 08-31-2012, 05:13 PM
RGREGORIE's Avatar
OK so the seven wire three plug CD pictured above is for the jianshe 250. The 400 has a five wire cdi. Mike could you tell me what the numbers on your CDi are. It should start with JS or JT then some numbers.
Old 09-03-2012, 10:44 PM
mikertldg's Avatar
It says qiyi js 400 06 2008
Old 09-04-2012, 12:34 AM
RGREGORIE's Avatar
Thanks a lot
Old 09-13-2012, 10:17 PM
mikertldg's Avatar
Ok Lynn I am back from work! I did that test with the red and blue and green and white! I saw on my meter .2 ac volts and nothing on the orange to ground! I used the ground on the battery, I dunno I that makes a difference or not
  #15
Old 09-15-2012, 08:01 PM
LynnEdwards's Avatar
Electrical Expert
0.2 VAC is probably OK based on how other CDIs that I am familiar with work.
So you have power going to the CDI, you're getting a trigger signal (the 0.2 vac), and you not getting any voltage out. So that points to a bad CDI.
  #16
Old 09-15-2012, 09:59 PM
mikertldg's Avatar
Ok! I am goin to look on eBay for a Cdi does it have to be exactly the same as the one I took off? I see some on there off of Chinese bikes that are 5 pin an look the same physically but not for my bike will these work?
  #17
Old 09-15-2012, 10:49 PM
RGREGORIE's Avatar
I just purchased a new cdi same as yours. Try
chinesemoto parts or kazumausaonline or chinesemoto partswholesale.com they run anywhere from $68-99. Ebay I only found them for about $159-249.
Mine started right up
  #18
Old 09-15-2012, 10:52 PM
RGREGORIE's Avatar
Don't waste your money on trying a different five pin. The shop I bought my motor from tried using three differnt five pins and fried all three trying to save money and not buy me a new one..
  #19
Old 09-15-2012, 11:34 PM
mikertldg's Avatar
I bought one that is for it from chinesemotoparts that was only 68 but I had to spend a hundred in order to checkout but oh well I will hopefully have a good quad after for only 600 buck!
  #20
Old 09-15-2012, 11:36 PM
mikertldg's Avatar
I don't know how long till it gets here but will let you all know if it works
Quick Reply: 06 jianshe 400 no spark somtimes
