Hensim
Old 05-07-2013, 06:10 PM
dukeden2000's Avatar
Default Hensim
I have 110cc and 125cc hensim four wheelers. When parked last fall they both ran great. Now not so much. I cleaned the carbs and replaced the spark plugs and still no luck. they will start and idle but bog and stall if i give throttle. Help??
Old 05-07-2013, 07:14 PM
Jaster94's Avatar
HOW did you clean the carbs? did you remove the jets? if not, therein lies your problem. a fuel delivery issue. it's been my experience 99.9% of the time when a quad bogs down, the main jet is partially plugged/clogged. remove the jet, clean all orifices. you should see daylight through everything and down the center of the jet. that'll fix you up.
Lucas Bohanan
09-29-2015 01:16 AM
elpayaso
06-03-2015 10:39 AM
elpayaso
05-30-2015 05:43 PM
bamax100
1) Engine problems..
8
12-12-2014 03:37 PM
Quick Reply: Hensim
