2001 kasea skyhawk 150
Old 12-18-2013, 01:57 PM
dave13net's Avatar
Unhappy 2001 kasea skyhawk 150
hello, new to this site. my daughter has a 2001 kasea skyhawk 150 had to replace isolator between carb and cylinder (bought online at a&j parts).removed carb to also clean out carb bowl,gasket looks ok so put back together (rubber gasket). well carb gasket leaks,took apart again, got gasket material and made my own. ran for alittle,now gasket leaking again.looked online to find parts again, a&j doesn't sell the gasket,just wondering if anyone has an insight on where i could get this rubber gasket. any help would be greatly appreciated
thanks dave
Old 12-20-2013, 06:00 AM
brumbear's Avatar
The chinese motors are pretty much all the same the difference comes in the style of motor so any motor with the style you have should fit. I believe you should have a small fan kind of attached to the cyl any tao tao or Roketa 150 is the same or should be.
Eagle Atv Parts
Old 12-20-2013, 08:28 PM
dave13net's Avatar
Default carb gasket
hey. thanks for the reply,looked at there site found carb pic that looks like mine,but still no seal listed in that section well this is a start and i did e-mail them. thanks for the info
dave
Old 12-21-2013, 09:57 AM
LT80's Avatar
LT80 Expert
Kasea isn't Chinese . They are Tiawanese.
Maybe that fact will help you find parts.
I'd like to know more.
Is it sucking air or leaking fuel out?
Old 12-21-2013, 10:26 AM
Zrock's Avatar
Super Quad Patrol
What works well is red RTV automotive silicone. Put some in the track for the o ring put the o ring back in and then put some on the mating surface. Bolt everything back together and let it cure for 12-24 hours. did mine this way and never had a issue. This method is used all the time for sealing rc carbs.
Old 12-21-2013, 05:02 PM
brumbear's Avatar
+1 just make sure you let it cure and it's clean and dry when you apply it.
Old 12-21-2013, 08:56 PM
dave13net's Avatar
Default fuel bowl gasket
well, fixed it and know one will ever guess what i used!!!! it was leaking fuel,also i have a fuel filter in the line and the motor would not pull fuel through, so took it out, can blow air through, but no fuel. starts, runs fine now.
P.S. i used a piece of rubber pond lining and cut to size.........
r1pilot83
Utility ATVs
15
11-25-2019 11:39 PM
35dodge
09-29-2015 09:40 AM
maveikfe
1) Engine problems..
09-24-2015 10:36 PM
Bonzhonda300ex
TheATVSuperStore
09-17-2015 01:21 PM
Ricardo Covarrubias
09-17-2015 08:28 AM
Quick Reply: 2001 kasea skyhawk 150
