1997 suzuki 250 quadrunner
Old 03-26-2014, 07:00 PM
jasonquadrunner's Avatar
Default 1997 suzuki 250 quadrunner
i have a 1997 250 quadrunner it has low mileage and it only got ridden once or twice a week and put in storage all winter. i got it out and you have to crank it forever to get it to start and when it finally does it wont idle unless you keep hitting the gas. and wont run at low rpm. i removed the carb and cleaned it and replaced about everything in it and still the same thing. would like to get the quadrunner fixed it is a good quad
Old 03-26-2014, 10:01 PM
Best to rebuild a carb rather than trying to clean one and still have problems. Plenty of carb kits on ebay. http://www.ebay.com/itm/New-Suzuki-LTF250-LTF250F-LTF250-4WD-1997-1999-Carb-Repair-Kit-12-9906-/330950645492?pt=Motors_ATV_Parts_Accessories&hash=item4d0e3216f4&vxp=mtr"IF" you have installed a kit and still have problems,could be an air leak around the intake manifold/split manifiold causing problems,valves need adjusting,etc
2quiker
03-22-2022 08:36 PM
Dammar
04-20-2016 06:03 AM
lgardner61980
09-20-2015 01:32 PM
phummer3210
09-11-2015 03:47 PM
09-01-2015 11:59 PM
Quick Reply: 1997 suzuki 250 quadrunner
