New Tao Tao 2013 ata 250D
Just got this quad 4 days ago I have replaced the fuel filter, installed a fuel shut off valve. Also changed oil to valvoline atv 10 40 oil. Lock tighten the bolts for adjusting the chain. Any suggestions that I can also do please I am open for suggestions.
Thank you
TableTop
Thank you
TableTop
Buy some bearings for the front wheels, expect the stock ones to fail relatively soon and start looking for some bushings for your front/rear swingarms and make sure that the screws holding your front swingarms are properly sized, in my case I had them too small to fill the bushing which naturally wasn't good.
Expect the need to re-paint the racks assuming you've got them powder coated. It's a really shitty job on a stock model.
Also, check your rear swingarm (the one holding your rear wheels in place) periodically, on my ATV both of the pipes cracked 3/4 of the way through, if I hadn't noticed and turned back home things could've ended very badly for me, they're MUCH too thin and weak so I'd recommend you weld on additional pipes to prevent this from even happening.
Jeff Roper
02-01-2022 11:48 AM
