110cc choke issue
Old 02-12-2015, 06:38 PM
cyrilmjohns84's Avatar
Default 110cc choke issue
I got an 07 sunl 110 and when it is warmed up with the choke on it goes. I can't turn the choke off because it kills the motor so I run half open. I would like to put an aftermarket carb on it but I need suggestions on a setup. I read the 22mm mikuni will work but what jet setup should I use.thanks for the help
Old 02-13-2015, 03:33 AM
Try cleaning out the carb you have, it must have worked when new so some of the jets will be blocked with dirt.
Old 02-14-2015, 09:39 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Try turning out the fuel screw a turn or so.. if it doesnt get better your carb needs cleaning like merryman suggested.
Old 02-14-2015, 07:31 PM
whygostockcom's Avatar
Banned
More than likely the pilot jet is plugged. You can clean it or just buy another that is not an EPA carb. Whygostock has 2 different carbs available.
Bratman2
08-06-2022 01:42 AM
ghost civic
07-27-2015 03:15 AM
Waddell4436
1) Engine problems..
07-20-2015 09:46 AM
Waddell4436
Technical and How-To Articles
07-19-2015 04:22 PM
Bob Maurice
07-14-2015 09:05 AM
Quick Reply: 110cc choke issue
