when warm atv wont start /is it 2/4 stroke
No problem. Elevation as in Sea Level is 0 (zero) all the way up Mountain level. The elevation levels can affect how your quad is jetted. I know more so on a 2 stroke. Since you have an old carb. Take that old main jet and drill it out just a little bit larger than stock. Install the drilled main jet and see if this helps in heat.
Big600twin
06-10-2015 03:01 PM
