110cc has fuel & spark, doesn't run
Have a 110cc that has been running great.
Now it just doesn't want to fire up. It would fire up 1 or 2 times out the 30+ times I've tried to start it. It would run for a bit then die and no go after that.
It has a recently new carb on it. I take it all apart again and make sure it's clean. There is gas on the plug. I have a newer spark plug in it. It always has a very strong spark when testing.
I've got rid of the kill box, etc.
I've tried 2 different CDI boxes. I checked the valve clearance and was in the .002 range. I adjusted them closer to .005/.006 and tried that. NOTHING.
Where do I go from here?
I would say minimum 80-90. Anything lower, it won't combust. You should be reading 130+. Is this a two or four stroke?
Yes. I checked the valve clearance and they were .002 range. I adjusted them closer to .005/.006 and tried that, but no change. I might tighten them up a bit more again.
