Tao Tao 110cc maintenance questions
Hello Atvconnection! My daughter got a TaoTao 110cc quad for Christmas, and I had some questions on maintenance since I cant seem to find the info I want in its "manual".
What type of oil should be used? I believe the manual stated 15w40, so I figure a 10w40 weight should be more than fine, but do I need a specific type of oil designed for motorcycles/atv's since the engine/trans share the same oil? Should I avoid energy/resource conserving oils? Would a synthetic help it run cooler? Is there an oil filter or screen that I can clean? I cannot find anything in the manual. Also how much oil should the engine hold? 1 qt, 1.5qt, less than 1 qt? I cant find a lot of info in the manual.
Also, what is the correct spark plug part number for these engines? Im sure there are a lot of plugs that will fit and work well enough, but I want "the best" which would be the CORRECT spark plug.
Thanks everybody!
Thanks everybody!
Here's a Service manual in pdf. I am sure all the info you need will be in there.
http://canadattatv.com/wp-content/me...e%20Manual.pdf
Leo
Leo
The following users liked this post:
Samara Hayes (08-22-2020)
The manual that came with our TaoTao Ata110D atv only goes to page 40 lol
The manual states 15w40, and I figure 10w40 should be perfectly fine, but you say 10w30 would be better?
Do I need a specific type of oil designed for motorcycles/atv's since the engine/trans share the same oil? Should I avoid energy/resource conserving oils?
Is there an oil filter or screen that I can clean or replace? It seems like some say yes and some say there isnt. How much oil does this 110cc "gy6 clone"(?) hold?
Also, I thought the "correct" stock spark plug was NGK? I just cant seem to find the correct Ngk part number for this 100cc "gy6 clone". Usually when I look, ill find multiple sites listing multiple part numbers that all say they fit almost all scooters/atvs. What is the correct Ngk spark plug part number for this engine? Correct Ngk iridium part number for this engine?
AlphaQuad
10-29-2015 10:55 PM
