fixing chinese atv
fixing chinese atv
if you bought one or know anything about old Honda's you will know very well the up keep on these motors. if you do it right you can limit your time put into these. the first thing I would do is put in sealed bearings, swap the CDI, change grips is a must, swap shocks, and buy a few different sprockets for riding conditions. if you are lucky you got one with multiple forward gears, if not then trust me and get a few sprockets. exhaust is a must in order to lift it up off the ground I recommend getting the pit bike exhaust. and lastly I would worry about tires. good luck and ride hard
If youre like me and like to work in the garage these cheap machines are a great way to educate yourself and test your skills.
If you dont mind waiting for parts theyre dirt cheap directly from china.
If youre the kind that want something that just works you obviously need to put more money into it.
