Tao Tao 125 with the Forward neutral and reverse lever shifting problems
Old 04-27-2016, 08:20 AM
Steelersfan99's Avatar
Exclamation Tao Tao 125 with the Forward neutral and reverse lever shifting problems
I have a TaoTao 125 with the forward neutral and reverse lever it will go into reverse and move it will go into neutral but when I put it into forward or drive it does not move I was told it may be the sprocket on the output shaft but that was from the person I bought it from but when you put it into forward or into gear to drive you can hear it click but it doesn't move but like I said it will go into reverse and I can drive it backwards as much as I want any ideas of what I could do would be appreciated
Old 04-27-2016, 09:32 AM
Zrock's Avatar
Super Quad Patrol
If their is a shift linkage on the machine try disconnecting the lever and shifting into forward by hand. If its a solid shift arm with no adjustment make sure its not rubbing on something. Other than that it will be a internal problem and you will have to dig into it
Old 04-27-2016, 12:36 PM
I'm not familiar with these the shift arm came off but it attaches to a know coming from underneath it it shifts into reverse fine and back to neutral fine and you can feel it move forward to put it in forward but it won't move. I was told something about a sprocket by the person. I bought it from
Old 02-23-2021, 01:23 PM
Michael Kahly's Avatar
I'm having a problem with mine popping out of drive as your going.
Therock86
11-04-2015 09:02 AM
~Ray~
1) Engine problems..
04-22-2013 07:29 PM
rebelbull1
10-14-2010 03:53 PM
Quick Reply: Tao Tao 125 with the Forward neutral and reverse lever shifting problems
