Tao Tao 125 ATV
Old 05-17-2016, 10:14 PM
Steelersfan99's Avatar
Default Tao Tao 125 ATV
I have a taotao 125 ATV it have the shift lever has drive neutral and reverse it would gonin reverse and move fine but in drive nothing so I replaced the clutch and still nothing. You can feel it shift into drive but no movement. Need help don't know what else to try. I've replaced oil etc. Any help would be great
Old 05-18-2016, 09:38 AM
Zrock's Avatar
Super Quad Patrol
what kind of oil? was it wet clutch safe?
Old 05-18-2016, 12:34 PM
I used 15w40 and what do you mean about the clutch
Old 05-18-2016, 01:54 PM
Zrock's Avatar
Super Quad Patrol
If you use a oil that was not ment for a wet clutch the clutch will slip. Cannot just go to the local store and buy any automotive oil. I use rotella t7 in all my toys
Old 05-18-2016, 08:29 PM
I used rotella it's not slipping it has forward neutral reverose shift arm it will go into reverse and it has all kinds of power I can pull hills in reverse. When I put the lever forward to drive you can hear it click but it will not go forward I have even adjusted the screw for the clutch adjustment it is a brand new clutch.
Old 05-18-2016, 09:12 PM
Zrock's Avatar
Super Quad Patrol
It will slip in forward but not always reverse if the wrong oil was used. I had one that would never slip in reverse but always slipped in every gear in forward. What rotella did u use?
Old 05-18-2016, 11:20 PM
Rotella 15w40 which I got from a lot of threads I read and from a local dealer when I bought it I was in the same condition and the person said something about a sprocket.
Old 05-19-2016, 09:33 AM
Zrock's Avatar
Super Quad Patrol
do the tires move off the ground? I cannot see one of the sprockets being bad as they are just on splines so you would have no movement in any direction. Only thing i could see is a gear in the trans stripped or broken.. Any shavings in the oil when you changed it?
Old 05-19-2016, 12:35 PM
I'll try setting it up off the ground and see what happens. Also there were no signs of metal in the oil. Also the person I bought it from said they were told the sprocket on the input shaft.
Old 05-20-2016, 09:45 AM
Zrock's Avatar
Super Quad Patrol
For the life of me i cannot picture how a sprocket would slip going one direction and not the other.. Only thing i could possibly see if the sprocket was at the end of its life on the forward side and the chain is slipping. But that should be quite obvious
Quick Reply: Tao Tao 125 ATV
