new Taotao 110 owner. looking for advice
I recently purchased a Taotao ATA-110F ATV. I think its an 2007 or so model. It runs good after I get some heat in the engine. I'm looking for advice on what owners have done to these things to either better enhance their performance and reliability or just make them more fun to drive. Are there any mods that can be done to them?
I seen a youtube video where someone talked about having to replace the carb every year due to their cheap design. Is this true? I also have a metal gas tank which is starting to rust. Where can I get a plastic replacement?
It has a brand new battery and I just changed the oil and plug
Pretty much the same machine as the gio 110 hummer. Those have a plastic tank.
Carb if you do not have a fuel shut off put one in and use it. On out 110 the carb would leak if it just sat but was fine as long as it was running. To lazy to rebuild carb. I would look into widening the machine. Pretty tipsy that's why I upgraded my little ones to a 125
Thanks. I will look into that. Before that happens though, I need to address an issue I have been having for the last two days.
It is extremely difficult to get this thing started. It just won't turn over. Sometimes it feels like it's about to and then just dies as I let the switch go.
I tried so long today that I ended up draining the battery. Once the battery was charged, I tried again and got it going but only if I hit the throttle as soon as it turns over. It will not stay running though. It dies if the ATV comes to a stop at idle. It will fire back up but again, you have to hit the throttle right away.
What I did notice is that the headlights will be nice and bright when the kids are running it around the yard but as soon as they slow down and come to a crawl, the lights will dim out until the ATV just stalls out. Almost as if the battery is dead but it does fire right back up.
Side note, I remotely shut the ATV off a few days ago and it would not start. I had no brake lights when applying the hand brake and the battery voltage went to zero when I hit the start switch. I ended up pulling the battery out and checking it on my charger and it was fully charged. I put it back in and the ATV fired right up like normal. Now I have this other issue today
Can anyone offer me any insight on what to check? This new toy has now become a pain in my side.
Not all carbs use a gasket but o-rings that can be reused. I use dialetric grease on them to keep them pliable. You can get gasket material at any auto parts store and make your own. Chinese carbs are so cheap in cost that a rebuild kit is not cost effective, if you can even buy a rebuild kit for them.
before you go ripping the carb out try turning up the idle slightly. Looks like that machine has no hours on it? If it has little to no hours on it it will need some run time to loosen things up. Shut the lights off that will give you more juice for starting. From factory battery are under sized. Even on my brand new one i have to hit the start button a few times to get it off a compression stroke then it will turn over easily and start.
