125cc Tao Tao needs more low end
Old 08-20-2016, 01:45 AM
1stimer87's Avatar
Default 125cc Tao Tao needs more low end
Any idea on what sprocket setup i can go with to increase low end Torq?
Old 09-09-2016, 06:44 AM
Bratman2's Avatar
I would take them off and measure them. Search Ebay and reduce the front by 2 and add 2 two to the rear. Then your chain still fits and it will be geared down a noticeable amount. They are fairly cheap. You just want to confirm chain size, bolt pattern and many of the front ones will have inside/outside splines. I got a front one for my Granddaughter's Panther 110 for under $10.00.
Old 09-09-2016, 12:03 PM
DirtDevil101's Avatar
You can also do the math...an example of the suggestion above...let's say the stock gears are 47(rear)/15(front)...that would yield a 3.133/1 ratio...if you do as suggested above you'd have 49/13 or 3.7692/1 ratio...the ratio being that for every 1 turn of the rear sprocket (wheel) requires 3.769 turns of the front sprocket...this will indeed increase your low end but will limit top-end speed...
The above is a 19% gear reduction and may be too aggressive, but that's a personal decision...
Old 09-10-2016, 09:39 AM
Bratman2's Avatar
The little 110 Panther was more like a mid 30 something rear, maybe 35 or 36. I think a 15t front. It would do 20 mph or so with the throttle limit screw ran nearly all the way in before I changed the front sprocket. Count your teeth. They are cheap enough if you search to buy extras to try. Heck, even the chains are fairly cheap. I had plans for more work before my youngest daughter remarried and the little 110 left our house.
Old 09-24-2016, 12:34 AM
1stimer87's Avatar
I ended up going 12t in the front and a performance Cdi. Very noticeable difference
Old 09-24-2016, 07:18 AM
Bratman2's Avatar
Good!
rottwolf
09-03-2000 08:37 PM
YUKONGT
08-11-2000 12:31 AM
Skunky
06-30-2000 01:02 AM
THEXOTIC1
06-23-2000 05:02 PM
quad500/650
05-22-2000 11:23 AM
Quick Reply: 125cc Tao Tao needs more low end
