Help understanding electrical/lights
Hi everyone -
Now that I have these two Tao 125's up and running, I want to play around with upgrading the lighting. I'd love to do a LED head light, brake light, and also add additional parking lights/LED light strips.
I have no idea what the electrical system is like or how to "tap" into it. Anyone have any tips on starting this upgrade project? These things run on a 12v6ah battery -- not sure how much load this battery can sustain. I guess I don't know where to start.
Thanks in advance!
Shane
Thanks in advance!
Shane
Headlights maby but taillights no... Taillights come on when depressing the brake to start
However in some cases the "running" lights wires may pass through a relay switch which is activated only when the engine is running. This is to prevent battery drainage if one forgets to switch off the lights.
Or my way. I have fit extra led lights on my bike.
Follow the wires from the head lamp until the 1st sockets.
Using a voltmeter measure the voltage between the 2 wires (or 3 wires - colours vary but usually green or black is ground and red or blue positive). Anyway the voltmeter will tell you which is which. It's important to know which is positive and which is negative because led lights have to be connected strictly with positive to positive and negative to negative. Wrong polarity may result in smoke!!!
To be sure that they are the lights wires 1 st measure with the light switch off (reading 0v) and with the switch on (reading 12,.. v). You could do the measurement in reverse order it makes no difference.
Now that we know which wire is which you can now tap into the relative wires and connect your led lights.
In the above proceedure I have assumed that the light switch is on low beam. If you want your led lights to be on only on high beam then you can do the same proceedure to find the high beam wire and connect it.
The same goes with tail lights.
If the led head lamps you are fitting are equipped with a high beam feature then it will have 3 wires - one ground(negative), one positive(low beam) and another one positive(high beam).
