Explanation of tire dimensions??
Old 02-23-2016, 07:47 PM
Kymco 450i's Avatar
Rim diameter needs to match the tire, in your case a tire that needs a 10" dia rim will fit on 10" dia rims that are of a different width. By changing rim width you only change the contact patch width of the tire after it is mounted.
So...by using a narrow rim the tire will have a slightly more narrow contact with the ground and if you use a wider rim the tire will have a slightly wider contact patch with the ground, using the same air pressure.
Old 05-16-2016, 09:23 PM
Gweaver's Avatar
I have a trx450r that is a 2004 and when I rev it higher it makes a grinding noise what could that be, and it doesn't mater the speed and r the gear it just maters the rev or rpm's need help
Old 05-16-2016, 09:26 PM
Gweaver's Avatar
Angry Grinding in the engin HELP
09-30-2015 01:37 AM
Ahtatu
09-28-2015 12:14 PM
PinkFloydEffect
09-25-2015 06:31 PM
cboler9
09-24-2015 08:35 PM
MikeyBoyesq
09-07-2015 10:44 PM
Quick Reply: Explanation of tire dimensions??
