2013 Polaris 500 HO
2013 Polaris 500 HO
I recently purchased a 2013 Polaris 500 HO it appears looking from the back that one side is higher than the other front looks straight but rear seems tilted slightly is this normal ? I measured the height from the ground up middle of rear tire to plastics and there is a 1.5 inch difference.
First off,may sound silly,but check that tire pressure is the same. This can affect the height. If tire pressure is at say 5 psi front and rear,check that the rear shocks are adjusted the same. Also check if the lower looking side rear spring is leaning inward,touching the shock body itself. This indicates a weak spring. Try adjusting the shocks up and see if this helps. If it doesn't may have a blown shock or weak spring on that side.
If everything else looks ok in the rear suspension then probably a blown shock.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
