General ChatAsk for ATV help above in the Brand Discussions Area. Use this forum to discuss Life, Music, ETC. Or discuss pretty much anything BUT no political or religious threads. There's an area for that.
I have a 05 artic cat 400 auto 4x4 and the 4x4 won't work I can hear a noise in,the front end when I push the 4x4 but nothing engages what could be causing this
I would inspect all the wires, check the fuse to verify its not bad, and also check your switch using a multi meter. If all those things check out okay I would assume the actuator is bad.
