2007 kawasaki bayou 250
So here is the problem . I recently purchased a 2007 kawasaki bayou 250 . I only payed 550$ for it because it needed some work . The day i got it home it ran fine all day long and the day after that . Then the next day i went to start it and it would bog down when given throttle . I have checked valve clearance , timing chain , drained tank flushed and put new gas in , and gone through the carb about 3 times and soaked it for about 2 hours . What im not getting is the fact that it starts up revs fine for about 10 seconds then starts bogging with any throttle this pattern repeats every time i shut it off and start it back up . Keep in mind it does smoke a bit so i didnt know if it might be low compression . I'm very mechanically inclined so any suggestion is help full .
First thing you do with a bike that isn't running right is check and change the plug. With a bike that smokes a lot it may well have fouled the plug. If a bike runs fine one day and not the next, it is not going to need any adjusters changing in the carb. It may have got dirt in, but get the dirt out and it will run fine again. Altering mixtures just masks the problem which will get worse, or clear and the mixture will then be out because you have altered it.
