Chain lube and anti sieze
Hi guys I just picked up an ATC and I've got a couple questions...
What type of chain lube should I be using? What the best?
What can I put on the wheel lug nuts to make it easier to take the tire off next time?
What kind of lube/grease should I be using for the splines on the axle?
Thanks
Thanks
I like the chain waxes, seem to attract less dirt.
Might want to hit the studs with a wire wheel. I don't use anything on atv lugnuts, but on my cars I use a little anti seize seeing as I live in the rust belt. You don't need much.
Any decent grease should work for the splines. I usually just use a bit of what I am using for suspension lube points.
mrtidy
02-03-2016 05:00 PM
Elkaholic
09-06-2015 02:44 PM
