no electric on Polaris Magnum
Only able to pull start or does electric starter work? If only able to pull start check the circuit breaker in the sealed pouch up from the battery. If corroded you wont have power to the starter or lights. If you're able to use the electric starter then see what the battery charging level shows at an idle. If only just shows battery voltage(12 volts) then probably the regulator as mentioned.
09-09-2015 06:57 AM
