90cc help
Old 05-02-2016, 10:44 AM
Twessell's Avatar
Default 90cc help
Dinli 90cc 2 stroke has spark but won't start has 55 psi compression I understand that low but it should still run on that right ? Need help what's next step
Old 05-02-2016, 03:24 PM
Old 05-03-2016, 11:48 AM
Twessell's Avatar
Should I get a carb too and will I need a CDi and such?
Old 05-03-2016, 03:35 PM
Carbs are cheap on ebay if needed.. Does it have spark? You can check by grounding the plug to the cylinder.
Old 05-05-2016, 08:57 PM
Twessell's Avatar
yes it does have spark and if I toy with carb enough I can get a sweet spot and get a blah blah sound like it wants to start like a weak little ignite could that be caused from low compression not getting enough combustion to really cause ignite and start?
Old 05-06-2016, 01:15 AM
One thing at a time. Just get the top end kit cause 55 pounds compression is way too low.It may try to crank,but you're beating a dead horse. You can try cleaning the carb after the top end is done or just get a cheap 15 buck carb on ebay.
Old 05-12-2016, 09:54 PM
Twessell's Avatar
would you be able to give me a short guide or walk me thru important steps on rebuilding this little dinli 90 I've never re built one before and do I need to remove motor from frame to re build it? Everyone says 2 strokes are easy. My re build kit should be here Monday so trying to prep and have the info I need to make it easier. I appreciate your help
Old 05-12-2016, 11:29 PM
Yes you can replace it with the engine in the frame in most cases.Several videos on youtube on two stroke top ends. Main thing is the piston pin clip open ends must face down or up not sideways and the ring stop pins lined up as explained in the video. Al marks on rings face upward. Polaris 90 head nuts torque at 14 foot pounds. The Dinli is similar in design and should be around the same.
Old 05-13-2016, 06:41 AM
Twessell's Avatar
do you know what kinda grease that is he used I didn't hear him mention I need to pick some up.
Old 05-13-2016, 07:46 AM
No special grease needed. Just use some 2 stroke oil on the upper bearing and pin, wipe the cylinder with a film of oil after you clean it,then use a little on the rings.You don't want to have a top end completely dry of lubrication when you start it.
Quick Reply: 90cc help
